| Does it cool down when you drive it? At 35 low and 200 high, what was the ambient air temp? 1oz isn't too much overcharged, but will affect performance, especially if you added too much oil. 6oz seems about right, but they may have added more oil when they charged it. Did the shop vacuum the system after you installed the new parts? How long did they vac the system if they did? Is it possible some contaminates got into the lines when you opened it up? It could have plugged the orifice tube, causing to not flow properly.
